Re: How to transfer HP48GX programs to HP50G Message #2 Posted by Marcus von Cube, Germany on 6 Sept 2006, 7:15 a.m., in response to message #1 by Prabhu Bhooplapur
Any suggestions on how to translate 48GX programs to 50G?
The easiest way is to transfer the objects in ASCII mode from the 48G to the PC. If you want integer numbers in programs being treated as reals instead of exact integers, set your 50g to approximate mode before the transfer. Or edit the programs on the PC in order to add decimal points to the numbers in question.
Conn4x comes with a built in XModem server for your 48G. It is a library which can be downloaded and stored in port 0 or 1 on your calc. On your PC you can have two instances of Conn4x open, one connected to the 48G (via COM port) and the other via USB to your 50g. Set the transfer mode on the sending side (48G) to ASCII (the right most icon on the toolbar) and then you can drag files directly from one calculator to the other.
Marcus
