Re: CAS commands don't work Message #3 Posted by James M. Prange (Michigan) on 5 Sept 2006, 6:58 p.m., in response to message #2 by James M. Prange (Michigan)
PS:
Umm, no not bug after all.
The CAT choose box has both EXP&LN which invokes a menu or choose box of exponential and logarithmic operations, and EXPLN, which transforms the trigonometric terms in an expression to exponential and logarithmic terms.
But I suspect that you chose EXP&LN when you really wanted EXPLN (like I just did).
But there does seem to be a documentation bug in the AUR manual, which lists EX&LN instead of EXP&LN in the full command reference.
