Re: HP-50/49/48G II Differences Message #12 Posted by James M. Prange (Michigan) on 27 Aug 2006, 10:40 p.m., in response to message #9 by Stephen Easterling
Thanks, James, for the updates and differences between these
calcs. I already have a 49g+ with ROM 2.00. After I updated the
ROM, the keypad problem went away and I have been happy ever
since. I actually like its color and layout, etc. and don't use a
serial port. So until the "collector" side of me gets around to
buying it just to have in my collection, I'll just be happy with
the 49g+.
Thanks again!
You're welcome, Stephen. Indeed, if someone already has a 49g+ and
is happy with it, I wouldn't recommend that he buy a 50g, although
it does have some improvements.
I do recommend that you update the ROM to revision 2.09 (build
92) though. This ROM is for both the 49g+ and the 50g; I surmise
that it detects which hardware it's installed on. See
here
for the download and installation instruction page, or
this
is a link to the .zip file itself (which now includes the new
equation libraries).
About the equation libraries: First off, they can be considered
optional; if you don't want them, then simply purge libraries 226
and 227 from port 2, and recover about 67KiB in that port. The
libraries supplied with ROM revisions lower than 2.08 use
unsupported entry points, so they're dependent on the ROM
revision, and in particular, won't work with revision 2.09. The
libraries included with the 50g and ROM revision 2.09 use only
supported entry points, so work with any 49 series ROM, at least
back to revision 1.18. So, if updating a 49g+ (presumably with a
revision lower than 2.08), then replace (or purge) libraries 226
and 227 in port 2; if updating a 50g (originally supplied with
revision 2.08), the libraries don't need to be replaced, although
you could purge them to recover some capacity in port 2.
Regards, James
