HP Forum Archive 16
Canon Palmtronic LE-84
Message #1 Posted by Antonio Maschio (Italy) on 25 Aug 2006, 10:34 a.m.
Hi everybody,
I know I'm a bit off-topic, but I need some collector's help.
I've just come across a Canon Palmtronic LE-84, a very beautiful basic calculator (no roots, no %, no memory), with red phosporescent numbers in a 8-digit display (image from Datamath).
Its Serial Number is 659870.
Now, I assume that 6 is the year number: 1976 (I retrived the dacade from Datamath - TI Related models), and 5 is the month (May).
Am I right? Anyone can clarify this point about SN and production dates for Canon calculators?
If another source is available, please, address me there.
Thanks in advance
-- Antonio
Re: Canon Palmtronic LE-84
Message #2 Posted by Frank Boehm on 25 Aug 2006, 11:24 a.m.,
in response to message #1 by Antonio Maschio (Italy)
> Am I right?
Actually - no. The LE-84 has been made in 1974. I have yet to find some kind of logic in their serial number scheme - they might have changed the first digit when manufacturing a new bunch. They certainly didn't start at 100000000 with each model, so there is probably another hidden trick :)
Message #3 Posted by Antonio Maschio (Italy) on 25 Aug 2006, 11:34 a.m.,
in response to message #2 by Frank Boehm
Do you mean that production started and ended in 1974?
-- Antonio
Message #4 Posted by Frank Boehm on 25 Aug 2006, 1:46 p.m.,
in response to message #3 by Antonio Maschio (Italy)
mine are datecoded 7407 to 7413 (CPU datecode), so that's probably mid 1974 production date, I'd expect an manufacturing timeframe of no longer than a couple of months - 1973 is highly unlikely, maybe until 1975, but unlikely
Message #5 Posted by Antonio Maschio (Italy) on 26 Aug 2006, 10:35 a.m.,
in response to message #4 by Frank Boehm
Please, Frank, write the Serial Numbers of your LE-84s. Just to check against mine.
Thanks.
-- Antonio
Message #6 Posted by Frank Boehm on 1 Sept 2006, 3:18 p.m.,
in response to message #5 by Antonio Maschio (Italy)
I have listed 7407: 673942 and 7413: 785973; no datecode for 768370 (which means the datecode was between 07 and 13). I probably have a couple more of these, but haven't noted down the ser#
Re: Canon Palmtronic LE-84 (Do you agree, Frank?)
Message #7 Posted by Antonio Maschio (Italy) on 1 Sept 2006, 5:38 p.m.,
in response to message #6 by Frank Boehm
Ok, thanks
So, interpolating:
SN = 785973 has a chip datecode = 7413
SN = 673942 has a chip datecode = 7407
SN = 659870 should have a datecode around 7406.
This should also mean that the calculator has been produced in February-March 1974 (since the chip is form 6th week of 1974, that is mid February).
-- Antonio
Edited: 2 Sept 2006, 7:34 a.m.
Message #8 Posted by Frank Boehm on 3 Sept 2006, 5:48 p.m.,
in response to message #7 by Antonio Maschio (Italy)
The datecode on the CPU is not the date of manufacture; I'd estimate 4-8 weeks between CPU manufacturing date (made in USA) and calculator manufacturing date (made in Japan). You should consider two other points as well: - they probably made production runs, probably only a couple of days per month for several months - CPU date code can easily be misleading/out of order, as different lots get mixed up
After all, you cannot determine the exact date of manufacture, I'd say April/May is a good guess here...
Message #9 Posted by Antonio Maschio (Italy) on 4 Sept 2006, 3:10 a.m.,
in response to message #8 by Frank Boehm
Right. I assume May 1974 on your word.
Thanks a lot.
-- Antonio
