Re: Little more help pls :) Message #4 Posted by Vieira, Luiz C. (Brazil) on 25 Aug 2006, 2:11 a.m., in response to message #3 by Troy
Hi;
to see the status of these flags (and any other) you may follow these steps: (there are others, these are the ones I thought being the easiest)
[PRG][TEST] ([TEST] is a softkey; press the key correponding to [F])
[NXT][NXT] (this brings the softmenu for flags)
2 [+/-] (or any sequence that puts flag # in the stack)
[FS?] (softkey; asks if flag #-2 is set) If you see a '1' (one) in the stack level 1 after [FS?], then flag -2 is set. If you see a '0'(zero), it is cleared. For testing other flags, like -3, simply pres:3 [+/-] [FS?] and check resulting value in stack level 1.
I hope this clarifies a bit.
Cheers.
Luiz (Brazil)
