Re: Recommendation for Repair of HP-11c? Message #2 Posted by Ron Ross on 22 Aug 2006, 2:49 p.m., in response to message #1 by Steve Seto
There are a couple of posters here who offer repair services as well. I have used none of them, but all have solid reputations as I can tell.
However, before you send off for repair, try a simple short the battery terminals with batteries still installed ie. use a paper clip to bridge the batteries (your actually also shorting out the cells momentarily as well). This is what is even recommended in the appendix of this model calculator. I might suggest to short the terminals out w/o the batteries installed first, then install, turn on and if no change, THEN short the batteries in the calculator.
