Re: HP-28S error Message #2 Posted by Vieira, L. C. (Brazil) on 18 Aug 2006, 3:41 p.m., in response to message #1 by aton
Hi;
The display area with the Y and the blinking square (input cue in replace mode) is usually filled with the softmenu labels. This means that, in your case, input is being performed. So, it seems to me your HP28S has a locked [Y] key. Maybe you can loose it, but I have no clue about how could you do that. Should check the calculator first.
Not so much of help, sorry.
Cheers.
Luiz (Brazil)
Edited: 18 Aug 2006, 3:42 p.m.
