Re: Any way to disable ON+CLX on the 41? Message #2 Posted by Eric Smith on 26 July 2006, 10:41 p.m., in response to message #1 by Geir Isene
I think you might be able to intercept it if you put custom microcode in block 4, where the diagnostic ROM normally would go, though I haven't checked. However, this would be incompatible with the 82160A HP-IL module when the printer function switch on that module is turned off, as it relocates the printer ROM to block 4.
