Re: 49 g+ won't turn on Message #4 Posted by chic thomson on 25 July 2006, 3:06 p.m., in response to message #3 by martin plass
In my 49G+, the stiff wire that interconnects the batteries is "a little shy", and shrinks back. Some flavours of batteries appear to have snubbier noses than others, and so dont connect. Anyway two minutes with a fine pair of radio pliers fixed it, and you can use a voltmeter to see where the connections are iffy!
hope this helps
chic
