Re: Compute some Eigenvalues first thing in the morning, and nothing worse will happen to you all day. Message #6 Posted by Valentin Albillo on 14 July 2006, 8:29 a.m., in response to message #1 by Eric Smith
Hi, Eric:
Eric posted:
"Actually it is fun, though a bit tedious."
Yes, I concur, I do it every morning as well and sometimes also before going to sleep. This is how I do it, extracted from my Datafile article "HP-71B - Math ROM Baker's Dozen - Vol 2", freely downloadable from here:
"The general case of finding all eigenvalues of any square matrix
is hardly any more difficult, as demonstrated by this 5-liner
that will accept any square matrix and will promptly compute
both the coefficients of its Characteristic Polynomial and all
its eigenvalues, real and/or complex:
1 DESTROY ALL
@ OPTION BASE 0
@ FIX 5
@ INPUT "N=";N
@ M=N-1
2 DIM A(M,M),U(M,M),C(N),D(N,N)
@ COMPLEX E(N)
@ MAT INPUT A
3 MAT D=CON
@ MAT U=IDN
@ FOR I=0 TO N
@ IF I THEN MAT A=A-U
4 C(I)=DET(A)
@ FOR J=1 TO N
@ D(I,N-J)=I^J
@ NEXT J
@ NEXT I
5 MAT C=SYS(D,C)
@ MAT DISP C
@ MAT E=PROOT(C)
@ MAT DISP E
Once the matrix has been entered, all it does is use DET (Determinant)
to find N+1 values of the Characteristic Polynomial, then
MAT ... SYS is used to explicitly find (and display) the
coefficients of this polynomial [...] then all its roots
(the eigenvalues) real and/or complex are computed at once
by PROOT and displayed as well.
Let’s test it with the same 5x5 matrix as before:
>RUN [ENTER]
N=5 [ENTER]
A(0,0)? 5,1,2,0,4,1,4,2,1,3,2,2,5,4,0,0,1,4,1,3,4,3,0,3,4 [ENTER]
-1.00000 19.00000 -79.00000 -146.00000 1153.0000 -1222.00000
(1.49766, 0.00000)
(3.36188, 0.00000)
(-3.55784,0.00000)
(5.67255,-0.00000)
(12.02575,0.00000)
so the Characteristic Polynomial is :
P(x)= -x5 + 19 x4 - 79 x3 - 146 x2 + 1153 x - 1222
and, as expected in this case, as this is a symmetric matrix,
all five eigenvalues are real (imaginary parts = 0):
x1 = 1.49766
x2 = 3.36188
x3 = -3.55784
x4 = 5.67255
x5 = 12.02575
You can verify them by checking that their product equals the
matrix determinant (DET(A) = -1222). To verify the Characteristic
Polynomial, you can apply it to the matrix itself: the resulting
value should be a zero matrix, i.e.: P(A) = ZER"
Best regards from V.
