Re: HP48GX Meta Kernel Message #3 Posted by Jeff on 12 July 2006, 7:57 a.m., in response to message #2 by Giancarlo (Italy)
Thanks Giancarlo!
After reading your response, I found that the way I downloaded the RECV.KER and MKRAM.KER files also included downloading the HP48 Server. This server library remained in port 0, which is why the RECV.KER execution bombed. After purging the server library from port 0, the command worked as described. I now have Meta Kernel installed! Thanks again for your response!
Take care,
Jeff
