Re: metakernel Message #5 Posted by Han on 30 June 2006, 6:59 p.m., in response to message #4 by bill platt
Interesting...so you mean that even though card slot one specifies 128 kB or less, you can put a 512 kB kard in there, and you will see ports 2,3,4, as well as having port one merged to sysmem?
No, card slot one only sees 128KB. However, due to the hardware of card slot one, you must have all banks be bit-wise the same. Anything larger than 512KB might cause hardware problems in both the calculator and the RAM card.
