Re: Verifying existence of a variable Message #3 Posted by James Jones on 25 June 2006, 7:39 p.m., in response to message #2 by Han
Yes, I do have a 48. Actually 2, a 48g and a 48gx. I started with a 21, upgraded to a 41C when it first came out and finally got these 48's on sale in 1995 more or less.
I learned to use and program the 41C in one weekend, but the 48s were not what I expected, so they mostly sat for the past ten years.
Learning now to use them. It's not so bad.
Thank you for the info on VTYPE. It will be used!
Also, I figured out that merely putting the variable name into an
IFFERR Variablename
THEN
ELSE
END
structure would not generate an error, but that putting the name there and then trying to RCL would generate an error which I could trap.
Two solutions in only one afternoon.
