Re: Opening HP-9825 ROM Cartridges Message #4 Posted by Tony Duell on 19 June 2006, 12:31 p.m., in response to message #1 by Vassilis Prevelakis
That's how I open them too (and for that matter, 9810, 9820 and 9830 cartridges come apart in the same way). Melting a little solder onto the head of the 'nail' improves heat transfer and makes it easier to get them apart. The 'nails' are an aluminium alloy, and solder doesn't stick to them.
To put them back together, I normally use countersunk self-tapping screws. Not original, but it sure makes it easier to take them apart again.
There are at least 2 types of HP9825 cartridge. One uses the HP custom ROM as you've discovered. The other uses a normal ROM chip, and a little TTL (address latch, address decoder). Note that the PCB in one type is fitted components-up, in the other type it's fitted components-down. This is somewhere in the schematics you have.
