HP-33s keystroke encoding and checksums [long] Message #1 Posted by Ivan Nejgebauer on 15 June 2006, 10:02 a.m.
It all began in an earlier thread, where those interested could follow the first steps towards reverse-engineering the encoding of HP-33s programs and the algorithm used to calculate their checksums. Now, with generous help from Paul Brogger and Derek Reyneke, I can present a (very) probable solution, or at least a solid foundation for one.
First, the checksum algorithm is, beyond doubt, a variant of CRC-16-CCITT. There seem to be doubts about the correctness of widespread implementations of this CRC (this thorough discussion suggests that HP-33s uses the "bad" variant, with a twist,) but these are beside the point; the goal is to identify the exact algorithm, not its adherence to a standard.
Second, equations are stored as ASCII strings, with a few non-ASCII code points for special symbols such as 'x' (times) and 'pi'. Decoding the full set of symbols shouldn't be difficult.
However, keystroke encodings are a bear. Each keystroke occupies three bytes, which translates to 2^24, or nearly 17 million, possible values. With a narrower checksum, collisions are guaranteed. Poring through hundreds of raw hexadecimal strings and trying to discern a coherent pattern is not easy. In the end, I had to make two key assumptions in order to move forward (and keep my sanity):
- The last byte of an encoding holds the additional argument (label or variable) of the command. For commands with no additional argument, the value of the last byte is zero.
- Successive label/variable names are encoded sequentially. With the first point in mind, all name codes must be non-zero.
... and the encodings finally started to make sense. What I have so far:
LBL A 02 B6 01 ; LBL B would be 02 B6 02, etc.
RCL A 33 C4 01 ; likewise
RTN 01 B7 00
+ 0B 31 00
x 0B 33 00
PSE 01 B4 00
Special equation symbols:
x 82
pi 87
Finally, I wrote a program to facilitate the search for further encodings. To use it, one would enter the following program into the calculator and obtain its checksum:
A0001 LBL A
A0002 <command>
A0003 RTN
(If the command accepts a label or variable name, use "A".) Then, the program is invoked as follows:
findenc "instruction name" checksum argument
where "argument" is 0 for commands without an argument, and 1 otherwise. E.g., for RCL A the invocation would be
findenc "RCL A" D85C 1
and for +
findenc "+" 9027 0
The program should print out a nicely formatted line with the instruction name and its encoding. It is written in ANSI C, and should compile and work regardless of the native host byte order and word size.
i.
/** findenc.c */
#include <stdio.h>
#include <stdlib.h>
static unsigned short crc_table[256] = {
0x0000, 0x1021, 0x2042, 0x3063, 0x4084, 0x50A5, 0x60C6, 0x70E7,
0x8108, 0x9129, 0xA14A, 0xB16B, 0xC18C, 0xD1AD, 0xE1CE, 0xF1EF,
0x1231, 0x0210, 0x3273, 0x2252, 0x52B5, 0x4294, 0x72F7, 0x62D6,
0x9339, 0x8318, 0xB37B, 0xA35A, 0xD3BD, 0xC39C, 0xF3FF, 0xE3DE,
0x2462, 0x3443, 0x0420, 0x1401, 0x64E6, 0x74C7, 0x44A4, 0x5485,
0xA56A, 0xB54B, 0x8528, 0x9509, 0xE5EE, 0xF5CF, 0xC5AC, 0xD58D,
0x3653, 0x2672, 0x1611, 0x0630, 0x76D7, 0x66F6, 0x5695, 0x46B4,
0xB75B, 0xA77A, 0x9719, 0x8738, 0xF7DF, 0xE7FE, 0xD79D, 0xC7BC,
0x48C4, 0x58E5, 0x6886, 0x78A7, 0x0840, 0x1861, 0x2802, 0x3823,
0xC9CC, 0xD9ED, 0xE98E, 0xF9AF, 0x8948, 0x9969, 0xA90A, 0xB92B,
0x5AF5, 0x4AD4, 0x7AB7, 0x6A96, 0x1A71, 0x0A50, 0x3A33, 0x2A12,
0xDBFD, 0xCBDC, 0xFBBF, 0xEB9E, 0x9B79, 0x8B58, 0xBB3B, 0xAB1A,
0x6CA6, 0x7C87, 0x4CE4, 0x5CC5, 0x2C22, 0x3C03, 0x0C60, 0x1C41,
0xEDAE, 0xFD8F, 0xCDEC, 0xDDCD, 0xAD2A, 0xBD0B, 0x8D68, 0x9D49,
0x7E97, 0x6EB6, 0x5ED5, 0x4EF4, 0x3E13, 0x2E32, 0x1E51, 0x0E70,
0xFF9F, 0xEFBE, 0xDFDD, 0xCFFC, 0xBF1B, 0xAF3A, 0x9F59, 0x8F78,
0x9188, 0x81A9, 0xB1CA, 0xA1EB, 0xD10C, 0xC12D, 0xF14E, 0xE16F,
0x1080, 0x00A1, 0x30C2, 0x20E3, 0x5004, 0x4025, 0x7046, 0x6067,
0x83B9, 0x9398, 0xA3FB, 0xB3DA, 0xC33D, 0xD31C, 0xE37F, 0xF35E,
0x02B1, 0x1290, 0x22F3, 0x32D2, 0x4235, 0x5214, 0x6277, 0x7256,
0xB5EA, 0xA5CB, 0x95A8, 0x8589, 0xF56E, 0xE54F, 0xD52C, 0xC50D,
0x34E2, 0x24C3, 0x14A0, 0x0481, 0x7466, 0x6447, 0x5424, 0x4405,
0xA7DB, 0xB7FA, 0x8799, 0x97B8, 0xE75F, 0xF77E, 0xC71D, 0xD73C,
0x26D3, 0x36F2, 0x0691, 0x16B0, 0x6657, 0x7676, 0x4615, 0x5634,
0xD94C, 0xC96D, 0xF90E, 0xE92F, 0x99C8, 0x89E9, 0xB98A, 0xA9AB,
0x5844, 0x4865, 0x7806, 0x6827, 0x18C0, 0x08E1, 0x3882, 0x28A3,
0xCB7D, 0xDB5C, 0xEB3F, 0xFB1E, 0x8BF9, 0x9BD8, 0xABBB, 0xBB9A,
0x4A75, 0x5A54, 0x6A37, 0x7A16, 0x0AF1, 0x1AD0, 0x2AB3, 0x3A92,
0xFD2E, 0xED0F, 0xDD6C, 0xCD4D, 0xBDAA, 0xAD8B, 0x9DE8, 0x8DC9,
0x7C26, 0x6C07, 0x5C64, 0x4C45, 0x3CA2, 0x2C83, 0x1CE0, 0x0CC1,
0xEF1F, 0xFF3E, 0xCF5D, 0xDF7C, 0xAF9B, 0xBFBA, 0x8FD9, 0x9FF8,
0x6E17, 0x7E36, 0x4E55, 0x5E74, 0x2E93, 0x3EB2, 0x0ED1, 0x1EF0
unsigned short
crc_ccitt(unsigned char *buf, unsigned len) {
unsigned short crc = 0;
while (len--)
crc = (crc << 8) ^ crc_table[(crc >> 8) ^ *buf++];
return crc;
int
main(int argc, char *argv[])
long i;
unsigned char ibuf[9];
unsigned short crc;
char *iname;
int arg;
/* instruction name, CRC, argument */
if (argc < 4) {
fprintf(stderr, "Usage: findenc <insn-name> <crc> <arg>\n");
return 1;
/* extract and prepare arguments */
iname = argv[1];
crc = (unsigned short) strtoul(argv[2], (char **) NULL, 16);
arg = *argv[3] == '1';
/* buffer setup */
ibuf[0] = 0x02;
ibuf[1] = 0xB6;
ibuf[2] = 0x01;
ibuf[5] = arg;
ibuf[6] = 0x01;
ibuf[7] = 0xB7;
ibuf[8] = 0x00;
for (i = 0; i < 65536; i++) { /* 2^16 */
ibuf[3] = i >> 8;
ibuf[4] = i & 0xFF;
if (crc_ccitt(ibuf, 9) == crc)
printf("%-16s%02X %02X %02X\n", iname, i >> 8, i & 0xFF, arg);
return 0;
Edited: 16 June 2006, 3:12 a.m.
