Re: Copying Private HP41 programs Message #6 Posted by Etienne Victoria on 12 June 2006, 1:11 a.m., in response to message #5 by Bill Lafferty
Yes we are.
You can not act directly on a program located on tape, card or floppy.
First you have to load it in your calculator. Then remove the private flag and write it back on mass storage.
However, it seems we have to solve 2 different problems here:
1 - How to remove the private flag from a program you have successfully loaded from mass storage (this is the main thing we're discussing).
2 - Rereading your first post, I see that you get a "medium error" message which is a completely different issue. This message can appear when the medium is either defective or partially/completely erased (or for a floppy when trying to write a write-protected disk).
Therefore, problem 2 should be solved before you have any success with problem 1.
Greetings from France
Etienne
Edited: 12 June 2006, 1:12 a.m.
