HP Forum Archive 16
IR Printers 82240A vs 82240B
Message #1 Posted by Han on 2 June 2006, 4:44 p.m.
Does anyone know the difference between model # 82240A and model # 82240B? What were some of the updates to version B? I recently obtained an HP 82240A which seems to work without any problems with my HP48 calculators. It apparently also works with the HP95LX AC adaptor!
Re: IR Printers 82240A vs 82240B
Message #2 Posted by jbssm on 2 June 2006, 5:10 p.m.,
in response to message #1 by Han
as far as I know, the only difference (besides a green led vs a red one) is that the character subset in the B version is a bit bigger, but it doesn't really make a difference in final output and you can choose an option at least in the 48G series to work with one or the other.
Message #3 Posted by Virgilio Guillen on 2 June 2006, 5:30 p.m.,
The 82240B has an extended caracter set ECMA 96. It was introduced for the HP-48 series.
http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/archv009.cgi?read=23762
Virgilio
Message #4 Posted by James M. Prange (Michigan) on 2 June 2006, 9:46 p.m.,
Note that although the ASCII characters match in the two character sets, the non-ASCII characters (128-255 decimal) don't. The 48 and 49 series include the OLDPRT command to remap, where possible, the new calculators' character set to the 82240A's character set, and otherwise the remapping is to character 127. All characters actually used in built-in command names are remapped correctly. The remapping string is stored in the reserved variable PRTPAR, and you can change it if you prefer. If you run OLDPRT and then print to an 82240B, the remapping will be incorrect; in this case just purge PRTPAR (the default PRTPAR will be created it as needed), or change the remapping string to "", the empty string.
Of course a pair of escape sequences for switching character sets were added; these are ignored by the 82240A. The 82240B uses the Roman 8 character set by default, so older calculators work just fine with it. Any printing (except by the CR command, and perhaps the PRLCD command) from the 48 series starts out with the escape sequence to switch to the new character set, so it works fine with them too (as long as the remapping string is empty). If you print to it with a 48 series, and then, without doing a reset or power OFF/ON, print to it from a calculator using the Roman 8 set, it will use the wrong character set.
Besides adding the modified ECMA-94 (ISO-8859) Latin 1 character set, some of the characters were modified to avoid having characters with descenders meet the top of characters in the next row.
Also added is a "low-power" mode. When running on battery only, it switches to this mode after about ten minutes of inactivity. It doesn't switch to this mode when external power is supplied.
A visible red "power on" LED is added, but note that this is turned off in the "low-power" mode. Unless you want to retain mode settings or data still in the input buffer, I advise switching the printer off when you're through using it; even "low-power" mode must use "some" power.
The dot on the power switch seems to be red on the 82240B, and orange or green on the 82240A.
The "ID letter" at the end of the self-test is G on the 82240Bs that I've seen, and D or not present on the 82240As.
Of course there could be internal changes to either the 82240A or 82240B.
Scans of the Owner's Manuals for both models are included in the latest MoHPC CD ROM set / DVD, and additional information is available here.
James
Edited: 3 June 2006, 5:02 a.m. after one or more responses were posted
Message #5 Posted by James M. Prange (Michigan) on 2 June 2006, 11:04 p.m.,
in response to message #4 by James M. Prange (Michigan)
PS:
Except within column graphics escape sequences, unused ASCII control codes and escape sequences are ignored by the printers. These are (in decimal notatation) control codes <0>-<3>, <5>-<9>, <11>-<26>, and <28>-<31>, and escape sequences <27><167>-<27><249> in the 82240A, or <27><167>-<27><247> in the 82240B.
ASCII control code <127> and non-ECMA-94 codes <128>-<159> are printable characters on these printers.
Character <160> (ECMA-94 non-breaking space character) prints as a space in the ECMA-94 character set. In the 48 series, it's displayed as a space, and the compiler treats it as a separator. In the 49 series (using the built-in fonts), it's displayed as the Euro symbol, and it's not a separator. The printers don't have a built-in Euro symbol, but I suppose that a column graphics escape sequence could be used for that.
James
Edited: 3 June 2006, 12:33 a.m. after one or more responses were posted
Message #6 Posted by James M. Prange (Michigan) on 2 June 2006, 11:23 p.m.,
in response to message #5 by James M. Prange (Michigan)
PPS:
I suppose that the escape sequence <27><0> is also "unused", or maybe the printers treat it as a "zero-length" column graphics escape sequence.
James
Message #7 Posted by Han on 2 June 2006, 9:55 p.m.,
Thank you all for the great information.
I have yet one more question. I my manual, it states that I should not use the printer with only the AC adapator. That is, I should have batteries installed even if I plan to use the AC adaptor. However, the manual never explains why, or what happens if I do.
Does anyone know why I should not use the printer with only the AC adaptor and no batteries?
Message #8 Posted by James M. Prange (Michigan) on 2 June 2006, 10:54 p.m.,
in response to message #7 by Han
I've used my printers without batteries (external power only) with no apparent problems, but I generally prefer to follow the instructions in the owner's manuals and always have the battery installed for printing.
Note that you don't have to use a "genuine HP" adapter, as long as your external power source meets the voltage and current requirements. The input power can be either polarity of DC, or it can be AC. I surmise that there's a bridge ("full-wave") rectifier in the circuit for external power.
James
Edited: 2 June 2006, 11:11 p.m.
Message #9 Posted by Virgilio Guillen on 2 June 2006, 11:22 p.m.,
The AC adapter does not supply enough current by itself during heavy printing (when printing lots of black). This is why the manual states that the AC adapter should not be used without batteries installed.
Message #10 Posted by James M. Prange (Michigan) on 3 June 2006, 12:23 a.m.,
in response to message #9 by Virgilio Guillen
At least that's what the owner's manuals state.
Experimentally, my printers have a problem printing solid black column graphics when powered by only an HP F1011A adapter (12VDC 0.75A), although they work fine when powered by only an HP 82241A adaper (9VAC 13.5VA MAX).
I suppose that what it comes down to is that the printers can draw power from the battery if the external power source isn't able to supply enough. Whether the battery is really needed seems to depend on which external power source you use.
James
Message #11 Posted by Han on 3 June 2006, 1:38 a.m.,
in response to message #10 by James M. Prange (Michigan)
James
I see. I also happen to own the HP F1011A adaptor (for my HP 200LX), and was wondering if it was possible to use it since the voltage rating for the printer (according to the manuals) states 9V-12V. However, I think I will stick to the HP 82241A adaptor since it is actually mentioned in the manual.
Message #12 Posted by James M. Prange (Michigan) on 3 June 2006, 3:31 a.m.,
in response to message #11 by Han
The box that the F1011A comes in says that it powers "HP Palmtop PCs" and "HP Infrared Printers". Also see the "All Parts" listing for the 82240A in the HP PartSurfer. The F1011A should be just fine, although the 82241A can supply more power.
I find the F1011A easier to carry with me. On the other hand, the F1011A seems to run a lot warmer; whether it's wasting more power as heat or it's warmer because it lacks the ventilation slots found on the 82241A, I don't know.
Of course any external power adapter that supplies 9-12 V AC or DC and at least 500 mA should also work. Don't pay too much for a "genuine HP" adapter on eBay, unless you want it as a "collector's item". That said, I expect that, with patience, you can probably get one at a price comparable to a new non-HP adapter.
On reflection, the problem with running on an AC adapter only may be that although the adapter may, on average, be able to supply more power than the internal battery, even after rectifying and filtering by the printer's circuits, under load the voltage from the AC adapter would have some ripple. Perhaps under a heavy load, the voltage between pulses can drop too low, and this is where power from the battery is needed.
James
Message #13 Posted by David Smith on 3 June 2006, 1:01 p.m.,
The B model has better power management and battery life. If I remember right it basically goes to sleep when idle for a while.
