Re: battery door for a 15C hand held calculator Message #2 Posted by Jeff O. on 31 May 2006, 2:35 p.m., in response to message #1 by Paul Osborne
Paul,
Unfortunately, hp seems to no longer stock the part, at least there doensn’t seem to be any way to select it at this link. You may get lucky and a kind soul (with spare parts) will be able to help you. However, most people treasure their 11C, 15C and 16C models as much as you do, so a spare door may be hard to come by. Absent such luck, your cheapest option may be to purchase a 12C on eBay, making sure to get an older one that uses the three A76/LR44/357 button cells. The current 12c and 12cp use a single CR2032 coin cell and the battery door is different. I am not sure when they switched over to the new battery type. I have a Malaysian-made unit from 1998 that has the old-style door. Older 12C’s from the early-to-mid 80’s made in the USA and Brazil are somewhat collectable, but I don’t believe that the later units made other places have achieved that status (yet?), so one may be had for reasonable cost. Maybe you could re-sell the 12C sans battery door.
My apologies if I have stated the painfully obvious.
Good luck.
Edited: 31 May 2006, 2:37 p.m.
