HP-71B Memory Modules shouldn't rattle, should they? Message #1 Posted by Mike on 25 May 2006, 11:51 a.m.
(Just kidding... I know they are not supposed to rattle)
I heard this strange rattle from one of my many HP-71B. I traced the sound to my card reader memory module. It was a Hand Held Products 96K RAM. I opened the module and found this little critter floating around in the package.
But what is it, where does it go and what does it do? I should know this but alas, I don't. The odd thing is the only place it looks like it was connected was on the ferite-like material. There doesn't appear to be any connection points for the coil wire. Strange (at least to me). You can see what appears to be one end of the coil but it doesn't appear to have been connected anywhere, as it's stuck to the resin and not near a solder point. Don't have a clue where the other end is.
I have located the place where it was mounted. You can still see the footprint impressions made by this (what I'm calling) ferite-like material.
Anyone know the purpose of this device? There are 3 boards and only the center board has the Transistor, surface mount component and this device. I have tested the RAM by loading program to it and it seems to work fine. I wonder, if this might have something to do with making a 64K partition. I have heard that these have such a partition. But when I freeport these, I can only make 32K IRAM. Might this be because this part is missing? Should the wire coil be connected somewhere? I ask this because the dark gray parts were connected to bridge the gap (shown in photo).
This part is also on one of my RAM/EPROM Modules but it's on the EPROM board and none on the RAM board, making me think, once again, that this might have something to do with the 64K chunk I was talking about.
Here it is on the RAM/EPROM board. This is just an example of another board that has this component. My board that has the fallen off component is RAM only
Anyone have any suggestions or ideas about this? I'll probably try to reattach it this weekend, if I can determine what it's for.
Edited: 26 May 2006, 1:31 p.m. after one or more responses were posted
