Nope! Not a resistor Message #3 Posted by Mike on 19 May 2006, 2:21 p.m., in response to message #2 by Thibaut.be
It's definitely not a resistor. It's a fuse. You see my confusion. In fact, I read it the other direction and thought it was a 22 ohm resistor. I put that small resistor in and it lugged down the current so much it wouldn't run. So there is no way it would run with 4K.
I already suspected it was a fuse, but thought they might be using a resistor as a fuse. Didn't even see the 5A till I had already removed it.
The green body color was how I came to determine it was non-flammable fuse.
Edited: 19 May 2006, 2:23 p.m.
