Re: Sitecom USB-to-Serial adapter Message #5 Posted by James M. Prange (Michigan) on 18 May 2006, 7:03 p.m., in response to message #1 by Thomas Okken
Any Kermit-based application that works with your operating system
and can use the ("virtual"?) COM port should work with any 48 or
49 series, except the 49g+. They all have both Kermit and Kermit
Server built-in, although a rather basic version of them.
With the 49g+, you'd also have to convert to IrDA or USB. I've
used the 49g+ with HyperTerminal and an RS-232/IrDA converter
(with Win98SE supplying a virtual COM port), but haven't been able
to get Conn4x to work with IrDA. Conn4x works with the 49g+'s USB,
and I believe that applications for Apple and Linux operating
systems are also available.
The 49 series (including the 48gII) has the Xmodem Server
built-in. As far as I know, this Xmodem Server is unique to these
HP calculators.
The 48G/GX/G+ has Xmodem built-in, but doesn't have Xmodem Server
built-in, although an Xmodem Server library is available. For any
application that expects an Xmodem Server, install the library.
The 48S/SX doesn't have Xmodem built-in, so to use an Xmodem-based
application with it, you'd have to find (or develop) an Xmodem
application, and in some cases, an Xmodem Server. Xmodem for the
48S/SX might be availabe at hpcalc.org.
All 48 and 49 series also have "Serial I/O" commands built-in, so
you could always develop your own communications protocol,
although for file transfers, that seems to me much like
re-inventing the wheel. But note that the XON/XOFF software flow
control capability was intentionally removed from the 49 series,
so you'd have to be careful not to overrun the 255-byte input
buffer. You might want to provide for error checking.
Working in assembly language, you can ignore the RPL input buffer
and build a string in temporary memory, and then replace its bytes
one at a time, as long as your routine is fast enough to check the
UART again by the time the next byte arrives. Again, you might
Besides HyperTerminal, HPComm, the Kermit-based "Connectivity Kit"
for the 49G, works with any 48 or 49 series. See
http://www.hpcalc.org/details.php?id=3713.
To use Conn4x, the Xmodem-based "Connectivity Kit" for the 49g+,
on a 48G/GX/G+, you'll have to install the Xmodem Server Library
(included with Conn4x) on the calculator. This library doesn't
work with the 48S/SX, although I suppose that one that does could
be developed. Be sure to use only the most recent version (Version
2.2 Build 2353, as far as I know) of Conn4x, available at
HP's site.
Regards, James
