Re: 41cx re-assign ON function? Message #6 Posted by Vieira, L. C. (Brazil) on 15 May 2006, 1:12 p.m., in response to message #1 by Hal
Hi, Hal;
based on the HP41 keyboard design, some other keys share either the same row or the same column, meanning that it depends both on the operating system (decoding/demuultiplexing row/column contact signals)and on the hardware to wake itself up. If the ON key has specific lines to its contacts, as it happens with the Pioneers, then it might be hardware-dependant only.
IŽd guess it is not possible to assign the on operation to another key unless you change the operating system as well. Maybe it is better to try cleanning the key contacts instead.
Sorry!
Luiz (Brazil)
Edited: 15 May 2006, 1:13 p.m.
