Re: hp42s memory upgrade Message #3 Posted by Vieira, Luiz C. (Brazil) on 6 May 2006, 11:06 p.m., in response to message #1 by Nat
Hi, Nat;
I tried finding the specs of the memory chip you mentioned, but I did not succeed. Sorry!
Anyway, I mannaged to upgrade some units, and I tell you that the chips I found and used mainly had their ID ended with '70' instead of '15'. I have two H48G carcass in hands right now and they have the following 32K-RAM chips:
CXK58257AM-70L (SONY)
W24257S-70LL (WINBOND) I removed two from an ancient sound card that comes with three units, with the following ID:MT62C256F-70LL I also used other units, and at least one of them was UMC made, as the one you mentioned. And I tell you that at least the HP42S' I used for a while (three units, now I have two) did not show any noticeable difference in power consumption wiht the RAM chips I used. I think that the '70' in the end of the ID's refers to access time (70ns), and that the 'L' and 'LL' may also refer to low power. If yours is a 15ns because of the '15' in the end of the ID code it means it may work because I remember removing some 8K RAM chips in some HP42S with ID codes ending with '15' as well. But the lack of a 'L' and the end of it may suggest that they are not actually low power. Because all RAM chips I used from the HP48G had the '70' in the end of their ID codes, I guessed that using the same chips in the HP42S would work. Well, I had no problems so far. I upgraded more than ten units, no complaints.
Sorry if I have no additional information about the RAM chip you mention in your post (um61256fs-15). The only reference I found here is a brief description of it as being a CACHE RAM 32Kx8 15ns. Anyway, I could not use any cross-reference about the ones I used, I mainly checked if their terminals were functionally the same prior to use them.
Cheers and success.
Luiz (Brazil)
Edited: 6 May 2006, 11:25 p.m.
