Hrast HP41X auto-off in emulated 48GX environments Message #1 Posted by Les Wright on 3 May 2006, 12:27 p.m.
Greetings group, I had an RTFM moment with respect to an earlier query, and I have been able to experiment with Hrast's HP41X binary code files in Emu48 and Power48 emulations of 48GX. It is actually painfully easy--in Emu48 one drops whatever HP41X binary object on the stack and EVALs, and in Power48 transfering it to the correct directory on the memory card makes it easy to find and load. So I have that settled fairly painlessly.
But in these settings HP41X emulates the "auto off" feature of the original calculator. Frankly it does it too well, and if one does not choose "true calculator speed" as an option, on a quick handheld or PC the emulated HP41 display cuts out after well under a minute, not 10 minutes as in the original HP41C series. Regrettably, it doesn't seem that "continuous ON" (alpha ON alpha) is implemented.
Is it just me, or has this experience been shared by others, either in emulated enviroments or on the actual 48GX calculator? It is a shame to lose out on the faster processor speed in emulated environments, but that display cutting out all the time is crazy-making....
Les
