Re: HP11C Message #2 Posted by Thomas Okken on 1 May 2006, 5:08 p.m., in response to message #1 by joe kinn
You probably accidentally turned the calculator on while holding the [.] key down. Which is also the way to change things back.
So, to be precise: turn it off, then press and hold [.], press and release [ON], then release [.].
Good luck!
- Thomas
