Re: HP-IL connection between 71B and 75C Message #2 Posted by Vieira, Luiz C. (Brazil) on 29 Apr 2006, 1:10 a.m., in response to message #1 by Roy Fletcher
Hi, Fletcher;
I have once connected both an HP75D and an HP71B through single HPIL cables. I remember that the HPIL closed loop cannot accept more than one controller, so when you connect more than one copntroler, all of them but one must be configured to listenner. The HP71B allows being configured and a listenner, but I cannot remember which command it uses. The HPIL manual for the HP71 HPIL interface describes this command and how to use it.
Sorry not answering your question, but I believe this follow up may give you a line of action.
Best regards.
Luiz (Brazil)
Edited: 29 Apr 2006, 1:12 a.m.
