Re: P41CX, Palm TX, and CPU Speed setting Message #2 Posted by Thomas Okken on 24 Apr 2006, 7:09 p.m., in response to message #1 by Les Wright
If the programs you're running on P41CX are HP-42S-compatible, you could try using Free42 to run them instead. Free42 uses the system clock to handle the NULL timeout, so the keyboard reacts the same regardless of how fast or slow your machine is, and, it *always* executes programs at maximum speed. (Plus, when Free42 is idle, it is *really* idle, so that the OS is able to go to low-power mode; P41CX busy-waits, preventing low-power mode, which is why it runs down the battery so quickly.)
In case you're not sure if your programs run on a 42S, there's a quick check you can try: import the *.raw files into Free42, and then set the Preferences so that printer output is sent to a text file; print your programs using PRP, and then search for XROM in the print-outs. If you don't find any XROMs, the programs should work.
(Note that the HP-42S and Free42 do not support HP-41-style Synthetic Programming, nor do they support full keyboard customization (USER mode).)
- Thomas
Edited: 24 Apr 2006, 9:29 p.m.
