Re: HP 33S FYI Message #2 Posted by Vieira, Luiz C. (Brazil) on 15 Apr 2006, 3:21 p.m., in response to message #1 by Trent Moseley
Hi, Trent;
thank you for this information. Good, indeed!
Just to go deeper: IF you still have the old batteries, is there a way to measure the voltages, amps capacity so we can have more info? I have already experienced some strange behavior in calculators with one dead battery amongst the other ones. One of them that called my attention was an HP41 that simply turned itself off everytime I tried to print trhough the IR module. I tested a pack of fresh batteries and it worked fine. Then I measured the voltage in the `old` four batteries and they all measured about 1.45Vcc (regular Alkaline). Then I decided to measure their voltage while in the calculator, and when the calculator was turnned ON, there was a strange drop from 5.8Vcc to about 5.1Vcc, no BAT annunciator. When trying to print through the IR module, the voltage dropped to less than 3.8Vcc and the calculator simply turnned itself OFF without any warning. Then I decided to go ahead and measure each battery with different load values. One of them (they were a bit old) was unable to maintain the expected 1.3Vcc shown with the others with about 11 to 12mA, it simply dropped it to 0.2Vcc. I took it as a failty battery, because all of them were from the same pack.
Well, I guess you have already tossed the old batteries away, but I thought I should mention these facts. I have some CR232 with low voltage I keep for experimental purposes, I'll go ahead with some tests with my HP33S this weekend and let you know.
Cheers.
Luiz (Brazil)
