HP Forum Archive 16
What is best module for 41c?
Message #1 Posted by martin cohen on 28 Mar 2006, 7:23 p.m.
I just got a 41c from a friend. It has the manuals, but no modules. The serial number is 2210S41778. It did not work until I twisted it somewhat (thanks Steve (Australia)). Now it seems ok.
My question: There are a number of modules available for it on eBay. What ones would be the best to get?
(I currently have 48s (S & G), 49G, and 49G+ - this is for fun)
Thanks.
Re: What is best module for 41c?
Message #2 Posted by Namir on 28 Mar 2006, 7:28 p.m.,
in response to message #1 by martin cohen
For a 41-C I suggest:
1-Quad memory module 2- MATH/STAT module 3- Advantage Module 4- X-Function Module
Your 41-C would have features liek an HP-41CV plus the extra math & stat features.
Namir
Message #3 Posted by Karl Schneider on 28 Mar 2006, 11:18 p.m.,
in response to message #2 by Namir
Mamir posted,
This is a good list (and in fact I have one or two of each of these, along with a 41C), but my ordered list would be the following:
1. Quad Memory module
2. Advantage Pac
3. Time Module
4. X-Function Module
5. Math/Stat Pac
The Advantage Pac contains most of the best features of the Math and Stat Pac's, improves upon others (notably SOLVE, INTEG, and matrix functions), and adds many more.
The Time Module gives capability for a clock, stopwatch, and handy calendar functions. Some application programs make use of these.
The X-Function module gives 124 registers of "RAM disk" storage and the functions to access that space, but not many "everyday" useful functions, unless you are into serious programming. The module can be used to transfer files from one 41C/CV to another, if the swap is done quickly. More convenient than a card reader!
BTW, your having to twist the calc to make it work seems to indicate a broken screw post. This is a very common problem, but it should be fixed -- with glue or "plastic weld", if I'm not mistaken.
-- KS
X-Function Module fun&games
Message #4 Posted by db (martinez, ca.) on 29 Mar 2006, 11:43 p.m.,
in response to message #3 by Karl Schneider
"The module can be used to transfer files from one 41C/CV to another, if the swap is done quickly."
Thanks Karl. I'm going to have to try that...........quickly.
Message #5 Posted by Vieira, Luiz C. (Brazil) on 29 Mar 2006, 1:27 a.m.,
Hi, Martin;
you have already read two very good suggestions, and I'd endorse the need of a quad memory module. Anyway, please accept two additional suggestions that are, in fact, these `build your own module set` currently available wonders:
Meindert Kuipers' MLDL 2000
Diego Diaz' Clonix/NoVRAM/NoV32 Modules
Seeing is believing...
Cheers.
Luiz, a believer (Brazil)
Edited: 29 Mar 2006, 1:28 a.m.
Message #6 Posted by James MacPhail on 29 Mar 2006, 5:48 a.m.,
I suppose there is no universal answer, as it really depends on what you are interested in doing. Therefore, I would suggest you learn something about all of the modules so you are better able to estimate what will be useful/amusing to you.
My choices:
1) The HP Museum CD or DVD. Lots of good stuff about the 41 and peripherals. http://www.hpmuseum.org/cd/cddesc.htm
2) Magnetic card reader, so you can save any important work. This might make the memory capacity of the stock 41C manageable.
3) HP-IL Module and printer. The IL interface opens up some interesting interfacing capabilities.
You could skip the card reader if you arrange another means of storage via HP-IL.
Message #7 Posted by Christoph Klug on 30 Mar 2006, 6:28 a.m.,
in response to message #6 by James MacPhail
Dear Martin,
now you own the HP41C model - but I prefer the HP41CX which includes complete main memory, X-Function, basic X-Memory and last not least the Time- Module.
To this I add a Double X-Memory Module + CCD-Module + EXT-I/O Module + IL-Module. This is my basic system setup :-)
A nice extension would be the EXT-IL Module, and by using a Clonix from Diego you place nearly the complete module collection above in only one plug in port - and this for a fair price.....
Regards - Christoph Klug
Message #8 Posted by Rick Meyerson on 1 Apr 2006, 8:16 p.m.,
The HP48G emulator module. Also the PPCROM.
Rick in Bel Air, CA
