HP Forum Archive 16
Custom menus with submenus on HP-49g+?
Message #1 Posted by Antonio Maschio (Italy) on 12 Feb 2007, 2:30 a.m.
I know how to customize a menu (editing CST or setting it with TMENU).
But how must CST be set to show a custom submenu, leading to another custom menu in the same directory?
-- Antonio
Re: Custom menus with submenus on HP-49g+?
Message #2 Posted by James M. Prange (Michigan) on 12 Feb 2007, 4:32 a.m.,
in response to message #1 by Antonio Maschio (Italy)
For a lot of information, try: http://groups.google.com/groups/search?q=custom+(submenu+OR+sub-menu)+group:comp.sys.hp48.
I believe that the custom menu techniques apply to all 48 and 49 series, and perhaps the 28 series as well.
James
Edited: 12 Feb 2007, 4:40 a.m.
Message #3 Posted by Gene on 12 Feb 2007, 8:04 a.m.,
Also, look here:
http://h20331.www2.hp.com/Hpsub/downloads/50gCalculator_modes_and_customization.pdf
Gene
Message #4 Posted by Dave on 14 Feb 2007, 11:04 a.m.,
in response to message #3 by Gene
Gene,
Looks like you updated all your training modules for the 50g. Nice work! Thanks to the training modules and the AUR you guys wrote, the 50g has a great set of documentation now. I can't thank you enough.
Message #5 Posted by Antonio Maschio (Italy) on 12 Feb 2007, 9:01 a.m.,
After surfing among your suggested sites, I managed the following CST:
{ ARCH REST READ ENGMODE MATHMODE HLP49.SD
   { "_MATH" «
      { SIMPLIFY
        { "INTG" « RISCH SIMPLIFY » }
        { "DERV" « DERIV SIMPLIFY » }
        { "HYP" « 12.0100 MENU » }
      } TMENU »
   { "_KEYS" «
      { ASN DELKEYS RCLKEYS } TMENU »
ARCH and REST are two programs I wrote for backup and restore; ENGMODE and MATHMODE set up approx and other flags on the run to set a completely approx mode or a completely symbolic mode (both are little programs of mine). READ is the HeadMan library reader, HLP49.SD is the Bill Markwick help system (non CAS). Of course I plan to extend it: this is only a sort of general scheme.
Hope this one will help anyone needing it. It's a simple one-level submenu, but a two-levels submenu may also be set, nesting the CST one more level: this could make the listing hard to read and to correct, though... The menus have a prepended underscore, to simulate the submenu symbol; I remember here that this is not a real submenu implementation, but rather an on-the-fly menu substitution; on one-level submenus like this, a way-back key is not needed; maybe on two or more levels submenus, but I haven't clarify the tecnique to use to myself yet.
Greetings and thanks James and Gene
-- Antonio
Edited: 12 Feb 2007, 9:01 a.m.
Message #6 Posted by Giancarlo (Italy) on 13 Feb 2007, 1:02 p.m.,
in response to message #5 by Antonio Maschio (Italy)
Hi Antonio.
How about sharing your solutions here in the Forum?
Or are you planning to release them on hpcalc.org?
Congrats for your efforts.
Ciao.
Giancarlo
