HP Forum Archive 16
Exchanging CUSTOM and MODE keys on an HP-49g+
Message #1 Posted by Antonio Maschio (Italy) on 10 Feb 2007, 8:21 a.m.
I'd like to access the custom mode (normally behind a left shift) directly, putting it in front, in the place of the MODE command, and putting the MODE command behind the left shift, since it's a command I used rarely - once the calculator is set up...-), and using the calculator in USR mode.
Is it possible?
-- Antonio
Edited: 10 Feb 2007, 10:52 a.m.
Re: Exchanging CUSTOM and MODE keys on an HP-49g+
Message #2 Posted by James M. Prange (Michigan) on 10 Feb 2007, 9:29 p.m.,
in response to message #1 by Antonio Maschio (Italy)
Sure:
\<< -22.1 KEYEVAL \>> 22.2 ASN
\<< -22.2 KEYEVAL \>> 22.1 ASN
James
Message #3 Posted by Antonio Maschio (Italy) on 11 Feb 2007, 4:53 a.m.,
in response to message #2 by James M. Prange (Michigan)
Many thanks, James.
-- Antonio
