Re: TDS COGO Problem Message #2 Posted by Randy on 8 Feb 2007, 7:19 p.m., in response to message #1 by Farzin
"TDSCOGO" is incorrect.
Try the card in slot 1 and alpha type "COGO" followed by the Enter key.
"TDS48" is for TDS Survey and Survey Pro cards.
If all else fails, restart the unit by holding down the A and F keys, press and release ON then press F to answer NO to the "Try to recover memory?" question. This does wipe your 48GX memory clean so it should be used as a last resort.
Edited: 8 Feb 2007, 7:20 p.m.
