Re: Classic Cleaning Adventure--or, My Recent Folly Message #11 Posted by Maximilian Hohmann on 7 Feb 2007, 3:28 a.m., in response to message #1 by Les Wright
Hi Les,
Quote: If I didn't get it for such a low price (for some reason the eBay public just didn't seem to want an HP80 at the moment) I would be darn insane with remorse.
For some reason, HP80s do not attract much interest from collectors, even if they appear on eBay only sporadically. I got mine shortly before Christmas from the Netherlands and was practically the only bidder, so the price was very reasonable (at least compared to other calculators of the same age).
So there is some hope that you will be able to replace yours with a better one in the near future without having to sell your house first :-)
Quote: I know there is no solution ...
As for the trim, with some patience and good fine-motorics in your fingertips you should be able to do something. You certainly know this article here already: http://www.vintagecalculators.com/html/restoration_of_calculators.html
But there is probably no way to repaint the keycaps in any decent way.
Your misfortune happened to me only once: I completely erased the label of a Compucorp power supply; luckily I cleaned this _before_ I started with the calculator itself.
Since then, I really only clean _dirty_ calculators. If they are clean when I get them (as is always the case when you buy from a collector!), I leave them as they are. Otherwise, I start with water only, if it dosen't help, I use a drop of "environment friendly" detergent, and if this dosen't help either, I try alcohol (ethanol). But nothing else.
Good luck, Max
