Re: Problem different now Message #8 Posted by Ed Look on 29 Jan 2007, 2:19 p.m., in response to message #7 by wancholo
Wancholo, with the original 49G+ (and some [very] inexpensive scientific calculators)... I know, different calculator, but still... there was a similar issue I had with batteries and the contacts. One klugey way around is to take some aluminum foil and fold it up and press it down into small, thin squares or dots, but thick enough still to be held between the battery terminal and the contact strip of the compartment. That does work, but over time, the piece of foil gets compressed more and loosens, so you may have to do it again from time to time.
I really hope you can get your 49G to work consistently for you.
Edited: 29 Jan 2007, 2:19 p.m.
