Re: Single variable stats, user guide unclear page 18-2 Message #4 Posted by Norris on 12 Jan 2007, 1:48 a.m., in response to message #3 by Ron
In the first paragraph of the "Entering Data" section (on page 18-1 of the HP-50G User's Guide), it indicates that you can "enter the data in columns using the matrix writer". This seems like the simplest, most straightforward way to do it.
After you finish entering data, and exit the matrix writer, the data will already be in the proper format (a single-column array). The only remaining step is to select STO-Sigma (to save the array into Sigma-DAT). Then you can run the statistics.
There are other ways to do it. For example, the User's Guide suggests that you could enter your data as a list, then convert the list into a single-column array. Or you could enter your data as a single-row array, then re-dimension it into a single-column array, as suggested above.
But if you use the matrix writer, you can enter the data directly into the single-column array format, with no conversions or redimensioning required.
