48G+ Case Crunching Message #1 Posted by Warren Anderson on 8 Jan 2007, 10:47 p.m.
48G+ passes self-test including keys, but any key pressed along the mid-right side causes a creaking crunchy squeeking noise, reproduced by pressing on the top case there too. I don't see any cracks, but do note that that there is an stepped edge along the right side where the top case lip slightly overhangs the bottom side (or the bottom is squeezed in) although the plastics all seem fairly stiff and sturdy.
This isn't a huge bother, but slightly annoying, and I'd fix it if the fix were simple. I doubt machines came from the factory this way, but never know...
The calculator is new to me and otherwise has no signs of wear or abuse.
I read but did not completely understand http://www.hpmuseum.org/cgi-sys/cgiwrap/hpmuseum/articles.cgi?read=125 "HP48 Disassembly," especially step 6 to separate the case halves. I surmise there are alignment tabs but don't how they are oriented or re-engaged.
Anything relatively non-destructive to try? Thanks!
