HP Forum Archive 16
HP 2225P with DB15 connector pinout needed
Message #1 Posted by Wilhelm Loidl on 29 Dec 2006, 3:24 a.m.
Anyone have the pinout for a Thinkjet 2225P (parallel) printer cable? It is not a standard Centronics, it has a 15 pin D connector at the printer (male). Thanks all.
Wilhelm Loidl
Re: HP 2225P with DB15 connector pinout needed
Message #2 Posted by James MacPhail on 29 Dec 2006, 5:19 p.m.,
in response to message #1 by Wilhelm Loidl
A while back, I found a posting from Tony Duell that seemed promising. I haven't tried it yet... I would like to know if it works.
... how I wired up a cable from a PC printer port (DB25) to the 2255P (DA15)
PC printer port -> HP portable thinkjet cable
PC TJ 1 -----Stb-----> 1 2 -----D0------> 2 3 -----D1------> 3 4 -----D2------> 4 5 -----D3------> 5 6 -----D4------> 6 7 -----D5------> 7 8 -----D6------> 8 9 -----D7------> 9 10 <---Ack------ 10 11 <---Busy----- 11 12 <--PE--+ 24 -------+ 13 <---Sel------ 12 15 <---Err------ 13 16 ----Init----> 14 19 ----Gnd ----- 15
Pins 12 and 13 may be swapped - I can't get either of them to change state to check.
-tony
Message #3 Posted by James MacPhail on 29 Dec 2006, 5:37 p.m.,
in response to message #2 by James MacPhail
I should add that I have great respect for Tony's knowledge and his many contributions; the only reason I think it may not work as-described is Tony's own lack of confidence re pins 12 & 13.
Message #4 Posted by Wilhelm Loidl on 30 Dec 2006, 3:08 a.m.,
in response to message #3 by James MacPhail
Thank you for the information!
I'll try the connection and inform you as soon as possible.
Best wishes to all forum-members for 2007!
Wilhelm Loidl
Message #5 Posted by Tony Duell on 30 Dec 2006, 5:01 a.m.,
in response to message #4 by Wilhelm Loidl
I can assure you that pinout works (I have used a 2225P with that cable). I can't remember what pins 12 and 13 are (some kind of error indicators?), they're not really needed for normal operation, hence my uncertainty
The diagram is how I wired my cable, but looking at it later I thought it looked more 'logical' (i.e. the pins that are used are in the same order at each end of the cable) if you swapped them round.
Message #6 Posted by Wilhelm Loidl on 30 Dec 2006, 10:51 a.m.,
Hello again - the working assignment:
PC -------------- TJ
1 -----Stb-----> 1
2 -----D0------> 2
3 -----D1------> 3
4 -----D2------> 4
5 -----D3------> 5
6 -----D4------> 6
7 -----D5------> 7
8 -----D6------> 8
9 -----D7------> 9
10 <---Ack------ 10
11 <---Busy----- 11
13 <---Sel------ 12
15 <---Err------ 13
16 ----Init----> 14
12,19 -- Gnd --- 15
Pin 12 from PC-side has to be grounded or the PC thinks, the printer has no paper...
Thank you all for helping me very smart and fast
Wilhelm Loidl
