Re: HP 48 Connection to a PC Message #2 Posted by James M. Prange (Michigan) on 17 Dec 2006, 9:17 p.m., in response to message #1 by Charles
Does anyone know if the serial cable for a 48G+ will work with a serial to USB connector ?
With MS Windows 98SE, it does for me, but I suppose that it may depend on the RS-232/USB converter and the drivers/software that comes with it. The main thing is that it will have to appear to Windows as a COM port, which I suppose is standard behaviour for these converters.
Does the software work with Windows XP ?
By all reports, both the Kermit-based HPComm and the Xmodem-based Conn4x work with MS Windows XP. To make full use of Conn4x, you'll need to install the included Xmodem Server library on your 48G+. Assuming that Windows XP includes HyperTerminal, you should be able to use that for either Kermit or Xmodem transfers.
Is the cable the same for the G series and S series ?
Yes.
Regards, James
Edited: 17 Dec 2006, 9:26 p.m.
