Re: Voyageur Rubber Feet Message #6 Posted by Les Wright on 16 Dec 2006, 6:49 p.m., in response to message #5 by Randy
Thanks Randy, I accept your offer. The back plate is peeling a bit so I should go with the thicker stuff. You have my address on record.
I am surprised I got no comments about my scotch tape pressure point fix. It seems to do the trick, but I worry about the long-term effects. But I was glad to get the thing working like normal--I was going nuts when I first got it!
Also, since I have agreed that this is to be a working calc and not a collector, I have decided to experiment a little. The scratching on the the aluminum trim was quite unsightly (I have a 15C that is near perfect, so I really notice), so I took a bit of 600 grit sandpaper and gave the surface a careful polish. I haven't been able to replicate the original brushed look of the aluminum, but the surface looks a lot less ugly, with the worse scratches reduced and the lighter ones buffed out. I wisely avoided the the display window and the plastic trim around the aluminum. Any thoughts on the appropriate and safest way to polish and clean scratched aluminum trim on the original Voyageurs?
Les
