Re: bad HP41CX? Message #6 Posted by Randy on 10 Dec 2006, 10:50 a.m., in response to message #5 by Gonzalo Fernandez (Spain)
Port 4 has the lines B3 and B4 connected together, it is the only port with that configuration. It is shown on the schematics and is obvious if you examine the port I/O block. I would remove the I/O block and look for battery corrosion, the most likely cause of your problem.
Edited: 10 Dec 2006, 10:51 a.m.
