HP-49g+ and bad keys Message #1 Posted by Antonio Maschio (Italy) on 2 Dec 2006, 10:28 a.m.
I have a HP-49g+ with the red key (the right or left shift? I don't recall) that at one pressure behaves like two pressures have been applied (that is it activates and then deactivates), and this is annoying, forcing me to look at the annunciator every time.
Besides, the zero key, until now perfect, begins to put an extra 0 after one pressure. It does this one of ten times now, but in the future?
The warranty is still active, and I could operate for a change, but have you got some good advice? I must specify that I have no skills in electronics, and opening a calculator for other than looking at some datecode is scaring, to me. So tell me, please, if there's something *easy* that I can do.
Thanks
-- Antonio
