Re: Other batteries for the HP-41? Message #6 Posted by Prabhu Bhooplapur on 1 Dec 2006, 2:44 a.m., in response to message #5 by Geir Isene
I have tried the N size 1.2V NiMH batteries and they last longer then the NiCd and these can be charged separately in a standard AA battery charger. You can insert two N size NiMH batteries in series in the place of one AA size battery in the normal charger. With this arrangement four N size batteries can be charged at a time in a standard two AA batteries' slots in a standard NiMH charger.
If you are equipped and willing to do some precision soldering onto the battery contacts within the calculator then it opens up the possibilities of using other battery packs,eg 6V rechargeables, externally. However, this is not so elegant, has some risk (soldering inside) and reduces portability of the calculator.
