Re: hp50g - solve Message #3 Posted by Shu Y Pong on 23 Nov 2006, 12:21 a.m., in response to message #1 by iamnew
Also, if you like, you can use the equation writer, right shift EQW, type in your equation an hit enter, you will then see your equation in the stack, then enter the variable you want to solve for in single quotes, 'x' on the next line.
Then left shift 7, S.SLV. You'll get the symbolic solver menu, then hit SOLVE or ISOL. Or SYMB then SOLVE then SOLVE again.
Edited: 23 Nov 2006, 2:15 a.m.
