Re: 42S Problem - Switches off straight away. Message #9 Posted by Vieira, Luiz C. (Brazil) on 22 Nov 2006, 10:58 a.m., in response to message #8 by David L. Jones
Hi, David;
any user-related data (programs, key assignments, matrices, register data, ALPHA contents, etc.) is erased after a master clear procedure, cofirmed with the 'Memory Clear' message you saw earlier. The small program Karl mentions may actually cause the auto-off behavior you described, because it sets auto-run flag (11) and turns the calculator off. In this case, subsequent attempts to turn the calculator on will cause it to turn itself off straight.
I have seen some HP42S with weird behavior, and in some cases I could interfere, resoldering the RAM chip and the other SMD components (two, I guess) solved the problem. Any chance that you'd open yours and try this? If you are not skilled in electronics maintenance, please, do not try it.
My 2¢.
Luiz (Brazil)
Edited: 22 Nov 2006, 11:01 a.m.
