Re: HP-50g. Cant' create directory on SD-card? Message #4 Posted by Gene on 17 Nov 2006, 4:47 p.m., in response to message #3 by Bent Rosnes
Working with SD cards and directories on them is really only minimally supported.
The filer does not do some things with SD cards and directories that it might could do.
So, essentially, what is in that PDF is the supported way of working with SD cards. That's what you've got, for good or bad.
Gene
