Re: Spice Battery Chapter 2 Message #8 Posted by Gerson W. Barbosa on 17 Nov 2006, 8:00 p.m., in response to message #7 by Dan Stein
The batteries in one of my 33C's get no charge when the plug is fully inserted in the charging slot. In this case, I stop inserting the charger's plug into the calculator just before I hear the clicking sound. This is easy to diagnose if you have a meter: measuring the voltage on the battery contacts, you should obtain 2.40 to 2.55 V, depending on the charge level. On measuring again while connecting the charger, the voltage will rise to 2.61V. If it drops to 2.50-2.55V when the plug is fully inserted, then it behaves like mine. In this case, just pull the plug a bit and check if the batteries are being charged (2.6V or more on the battery contacts).
Gerson.
Edited: 17 Nov 2006, 8:03 p.m.
