Re: Question about HP-11C screens Message #2 Posted by Randy on 15 Nov 2006, 10:16 a.m., in response to message #1 by Dave Demers
Take the batteries out both units and have a look. Early units had symmetrical silver contacts, later machines had a spring on the left and a gold plated pc board contact on the right.
Within the date code range you mention, if both units share the same design battery contacts, the displays are interchangable.
Quote: without too much replacement fuss
If it's your first time inside a Voyager, it is *not* an easy task. Even after having done dozens of these exchanges over the years, I still dread them, it is one of the most tedious repairs you'll ever encounter.
