Re: 48GX Repair Question Message #3 Posted by Han on 8 Nov 2006, 10:06 p.m., in response to message #1 by Ron
Opening the HP48
Repairing the HP48
These are my own docs on how to open and do repairs on the HP48. However, please be warned. MANY, and I do mean MANY, people have broken their HP48 because they have no idea what they are doing. I've seen a quite a few "for parts only" calculators on eBay that even refer to my two links above.
If you plan to open up the calculator, make sure you what it is you're getting into. The most fragile parts are the six twist-tabs that hold the PCB and keep it tightly pressed against the key contacts. Twist these too many times and you will break them, oftentimes rendering your semi-working HP48 quite useless except for parts.
Edited: 8 Nov 2006, 10:06 p.m.
