What's wrong with my HP25? Message #1 Posted by Karen on 4 Nov 2006, 12:06 p.m.
I have two HP25s "inherited" from my father. One of them does not work. The fault is nothing to do with the batteries, because I know the battery pack is okay from testing it with the other calculator (which works fine). If you put a decent battery pack in the dodgy model there is no response when you turn the thing on.
I also have two mains adaptors that came with the calculators, but I don't know if they work or not. If you plug one of the mains adaptors into the dodgy calculator, you get an "8" on the right hand side of the display and various flashing LED elements. Plug in the other adaptor and there is no response at all.
So, could anybody give me any help/advice on this problem...?
Thanks, Karen
