Re: Sticky on button HP32SII Message #2 Posted by Jeff O. on 24 Oct 2006, 7:49 a.m., in response to message #1 by Leo
Suggest you consult with Randy at Fix That Calc. Information on opening and disassembling pioneer models can be found here and here. As you will see, keyboard repair on these models is an iffy proposition, at best. There has been much discussion over the years of using ultrasonic cleaners to remedy contamination problems, if that is the cause of your difficulty. A search of the archives should yield some information.
